Fusion Manufacture
I'm having trouble posting 2D and 3D operations to one post
12 REPLIES 12
Message 1 of 13
rmurrayUKVY
240 Views, 12 Replies
I'm new to fusion manufacture but not new to CAM. My problem has something to do with saving the ramp or scallop with a 2D pocket. It is fine when I output the 2 pockets together and the ramp by itself, but one pocket and the ramp won't work.
I have tried bringing my tolerance and smoothing to .04" just to reduce the file size.  I don't think it has anything to do with my postprocessor because it will run 2 pocket operations with a tool change, but I could be wrong this is my first job with fusion.
I have attached my files.
Thank you in advance.
12 REPLIES 12
Message 2 of 13
a.laasW8M6T
in reply to: rmurrayUKVY
I've just tried posting a bunch of different combinations and all work just fine.
This is using the standard WinCNC post from the fusion library
is that the post you are using?
Message 3 of 13
rmurrayUKVY
It posts fine but when I go to the machine I get Error -Syntax - Command or File Not Found
Message 4 of 13
a.laasW8M6T
Does it give a line number that the syntax error is on?
That would point to which part of the code is giving problems
I cannot see anything unusual in the code the would cause such an error
Message 5 of 13
rmurrayUKVY
in reply to: a.laasW8M6T
No, I don't see a line number in the error.
Message 6 of 13
a.laasW8M6T
That is very odd
I don't have access to a wincnc controller so I can't test the code myself but it does run perfectly fine through the NC Viewer back plotter
Message 7 of 13
rmurrayUKVY
I know, when I import it to my machine it only previews the pocket for the #6 and the small holes. Not the 3D ramp toolpath. But I can import a file with just ramp just fine and that will run.
Message 8 of 13
rmurrayUKVY
I was wrong. It is something to do with the tool change. I just tried a file with two 2D pockets using different tools and got the error message.
Message 9 of 13
a.laasW8M6T
can you try setting the atc mode to 1
with it set to 0, you get the "M37 H" output
with it set to 1 you get "M37 T"
Message 10 of 13
rmurrayUKVY
You got my hopes up on that one, but it didn't work.
What is ATC mode?
Message 11 of 13
a.laasW8M6T
From the Win CNC manual
I still cant see any bits of code that will throw up any issues.
Does your machine come with any sample code that shows all the correct syntax for toolchanges etc?
There really isn't any difference between a single operation and multiple ops in terms of the code other than the G28 after the G53 at the end of both programs, but not between tools, but I wouldn't imagine that should cause any issues.
Message 12 of 13
rmurrayUKVY
I have this file that works with a tool change from Aspire.
Message 13 of 13
a.laasW8M6T
Comparing the Aspire code output to the fusion one, the aspire output isn't using M37 and G43 for tool length compensation, so I'm not sure how the machine is compensating for various tool lengths when it changes tools.
Maybe your machine activates the tool length on the toolcall?
I also note that its using feed type:
