Message 1 of 22
I just wasted a 3rd 4x8' plywood sheet because a cut was supposed to be inside and it was supposed to be outside or vice versa. How in the world am I supposed to reliably tell the difference? The arrow direction doesn't seem to have any significance, nor does the color. Like it or not (and I do not) the &(@&# CAM setup requires me to select every single cut separately, so the chances of making a mistake is especially high since there's no clear visible indication of the type of cut that is going to be made.
Is there some option to indicate inside/outside via color or some easily verifiable way?
