Fusion Manufacture
I cannot emboss my font over a cylinder.
6 REPLIES 6
ian1196
138 Views, 6 Replies
I am using Cdm.shx font because it is single line and appears to be equal spaced. I need help getting this text to emboss over a cylinder. When using Emboss feature, I cannot select the text. It works for other text fonts.
6 REPLIES 6
Warmingup1953
in reply to: ian1196
Will you be CNC machining this? 4 Axis?
ian1196
Yes, I will be machining in 3 axis.  I will find the angle of separation for the numbers. Ten set-ups will be made where each represents a digit on the "top". Each will be a subroutine. I will use a manual rotary and scribe one digit at a time on a 3-axis machine by calling the desired subs.  I have 8 cylinders and each part will have a 4 digit number. I want to capture the variation in "Z" for each number.
HughesTooling
How about just using 2d contour using the text then wrap. File's attached.
Mark Hughes
Owner, Hughes Tooling
ian1196
That method does not work. It is looking for a 5-axis machine. I only have a 3-axis machine. I just want to scribe that "3" in the middle of my example using 3 axis technology.
HughesTooling
As you don't have 4 axis I think your only option will be to create a plane for each letter using a tangent plane and set the angle between each letter. Then create a setup for each letter and use project in the manufacture workspace to create the toolpath for each letter. See attached design.
Mark Hughes
ian1196
Thank you very much. I have never used Project before. I have a CNC machine that I use for my hobbies and I try to learn something each week in Fusion 360
