I can't make a post
EmreYucel34
I can't make a post
EmreYucel34
Hello, I can not post the part I have shared, it gives an error, what settings do I need to make to create a post, thanks for your support, good day
Replies (17)
seth.madore
What post processor are you trying to use?
Seth Madore
EmreYucel34
Hi Seth, I would like to make it for Fanuc, thanks
seth.madore
You've defined your Setup as a Turning setup, so you just need to select an appropriate Turn/Mill post processor. What is the machine/control in question?
Seth Madore
EmreYucel34
Hello Seth,
The brand of the machine is NVX 1680 YCM, it has FANUC Server
Can you please share a video or link about how it is done? Thanks if I don't tire you,
seth.madore
That machine is not a lathe, it's a mill. Thus, you need to define a Milling Setup:
Without a Machine Configuration, you're going to get Euler angles (G68.2). You can change this with a proper machine configuration or post edits.
Seth Madore
hello emre,
Do you want to drill holes in 4 axes? I think the machine model is a vertical machining center.
Hello Emre,
Yes, our machine has vertical processing, diffuser attachment
EmreYucel34
Hello Seth,
The video gives an error and does not open for your information
seth.madore
Give it time to process, it usually takes several minutes to become available 🙂
Seth Madore
EmreYucel34
OK Thanks
Hi Emre,
  • Positioning the Part
    First, position the part relative to the origin. Make sure the part's orientation matches how it appears on a blank workspace in Fusion 360 (XYZ axis alignment).
  • Setting Stock and References
    After positioning the part, configure the stock and reference points accordingly.
  • Downloading the Machine Kinematics
    Download Autodesk’s 4-axis rotary machine kinematics from the cloud library.
  • Adjusting the Machine Kinematics
    • Disable the TCP (Tool Center Point) mode in the machine kinematics.
    • Set the rotational limits for the A-axis between -360 degrees to +360 degrees.
  • Integrating a Post Processor
    • Download a post processor like Fanuc Robodrill or Meldas from the Fusion post library.
    • Integrate the post processor into the machine kinematics.
  • Divisor Lock and Unlock Commands
    If the rotary axis (divisor) operates using M10 and M11 commands:
    • Define the corresponding codes for "unlock multi-axis" and "lock multi-axis" in the post processor settings.
Hello Emre,
I am grateful for your support and help, thank you, good day, good work
Hello Emre, I hope you are well, I'm making a mistake somewhere, but I couldn't find where I did it, can you help me on how to proceed with video? Thanks for your support, have a good day
Hello Emre,
What exactly are you stuck on? Can you write down the things you can't do and the things you want to do, I can make a video accordingly.
Hi Emre, I made the machine definition, I made TCP passive and adjusted the angle ranges, I share the screenshots, but it gives the error you have seen, define the corresponding codes for “unlock multiple axes” and “unlock multiple axes” in the post processor settings. could it be due to the statement, I guess I couldn't do it, thanks, I get the same error in both posts,
Hello emre,
Can you watch the video and get back to me after you follow these steps?
Hello Emre, I would like to thank you endlessly for your support, have a good day and good work.
