Fusion Manufacture
Hurco TMM8 not running on Post. Says it doesnt like G95
3 REPLIES 3
mitchsch24
128 Views, 3 Replies
So I have a TMM8 that Im trying to get to mill a sprocket profile, but it is saying that it doesnt like the G95. anyone have similar problems or know how to fix it?
3 REPLIES 3
seth.madore
in reply to: mitchsch24
Looking at the Hurco manaul, G95 is referring to feed per rev. How else do you command it to work in feed-per-rev mode?
Is it possible that there is another g-code that is active that needs to be cleared first? Have you attempted any manual edits or MDI commands to get it to accept the G95?
As it's a Hurco, are you able to program a simple piece at the control and then have it spit out g-code?
Seth Madore
My guess is you just can't use FPR when doing live tooling....Feed should be in IPM
Please click "Accept Solution" if what I wrote solved your issue!
mitchsch24
Oh I'm sorry I was confused. the code has g94 in it that is throwing a flag. I think that I need to run it with G95.
