Fusion Manufacture
How would one use FU360 to generate code to mill these bosses?
6 REPLIES 6
ian1196
216 Views, 6 Replies
In the following design, I want to leave the bosses. If I rough them out with Pocket and leave material for Contour, all the rigidity is gone. If I accept Pocket, I will get flats. Any suggestions?
6 REPLIES 6
seth.madore
in reply to: ian1196
Personally, I'd use 2D Pocket and enable "Finishing Passes". This will give you a finish pass at each depth cut, not only when it's all roughed out:
Seth Madore
ian1196
in reply to: seth.madore
Thank you very much. Can I get the center of the tool to not go outside of the boundary in 2D Pocket?
seth.madore
Like this?
Seth Madore
arendVisher
Another way to do this is using 'Stock Contours'
1)Create a new Sketch in the Design environment. This will be your boundary. In your case a smaller circle.
2)In 2D pocket under the Geometry tab select 'Stock Contours'
3)Select the new Sketch line (your smaller circle)
Finaly adjust the size of the smaller circle until you have the desired result.
ian1196
in reply to: arendVisher
It looks great but the gcode puts flats on the bosses. The bosses are likely too skinny for a Contour cut.
arendVisher
Can you help me understand what 'flats on the bosses' means.
