Fusion Manufacture
How would I cut two parts out of EPP foam at the same time? CAM
5 REPLIES 5
luke9HWU3
130 Views, 5 Replies
Like I said in the title, I am trying to use a CNC router on a block of EPP foam to produce multiple of the same parts.
The gap between each part is 6.351 mm - the diameter of the bit is 6.35mm. I have selected "both ways", "Use Slot Clearing" (with slot clearing width = 6.351mm) I have turned off the leave stock option. I know this is rather unconventional, but I am looking for speed rather than a smooth edge here. I would really like to only do one pass on both of these parts. Is there a way to force fusion into doing this without writing manual G-code? Thanks for any help.
5 REPLIES 5
seth.madore
in reply to: luke9HWU3
So, you're looking for something like this? (where red indicates the toolpath)
Seth Madore
luke9HWU3
in reply to: seth.madore
Yes, exactly. Thank you.
seth.madore
Easiest way would be to demonstrate it for you on your exact file.
Would you be able to share that Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
luke9HWU3
Here is an example. Thank you!!
seth.madore
Watch this and see if it answers your question:
Seth Madore
