how to use a 45 degree router bit to cut a angle
speerscustomcabinets
I am trying to figure out how to cut a miter joint on my CNC using a 45-degree router bit but can't seem to find anything to work. Not sure why this is so difficult but I am at my wit's end
The attached file is a simple miter but on the operations, I got to generate just dove to the bottom without clearing material from the top.
seth.madore
If there's one area that Fusion falls short in, is the needs of woodworking. For a feature such as this (and using a tool such as the one you're using), I would actually suggest creating a Form Mill and using 2D Contour with some Stock to Leave, Multiple Depths and a Taper Angle:
 I've attached the file for your review
Seth Madore
Warmingup1953
Why not trace a line projected onto a plane (Offset 0.4mm) with your large bit? I use a 91-degree included angle bit.trace.jpg
seth.madore
@Warmingup1953 the size of the OP's "vee" is much larger than they make a tool for (okay, maybe not, but it's very large)
Seth Madore
