Fusion Manufacture
How to use a 1/8 (.125) ball nose endmill for engraving letters?
4 REPLIES 4
derek_secord12
127 Views, 4 Replies
i used the engraver tab but when i put a ball nose on there it doesn't let me do it. I'm in school for this license plate project but our classes use MasterCam and I'm not a fan of it so i wanted to use fusion but the process is different of course.
4 REPLIES 4
I define it as a chamfer mill then load a real ballnose. Set the tip width to the largest it can be to still get a full engraving toolpath. Set the max depth as -.001 or whatever is required.
Please click "Accept Solution" if what I wrote solved your issue!
You may also want to consider single-stroke fonts and using the Trace toolpath, which would support a ball endmill
Seth Madore
jscott6SWZG
in reply to: seth.madore
I have been unable to emboss single line fonts.
Whats the trick?  On a curved surface?
I guess ill try a programmings method with double line font?
Funny enough the forums wont let you upload fusion files, but here is the Template I use.
Import that into your Templates and hopefully it works for ya.
https://drive.google.com/file/d/1jvNZQ2bl3GwTJv_NFi6gQ9nMRO_WHF24/view?usp=drive_link
