How to turn in the oppsite direction
Please i am having trouble turning in the opposite direction. I have the first setup which is cutting and turning from front to back. I want to create a 2nd setup that will do the same thing from back to front but also be a continuation of the old operations.
Fabbunny69
Hi, can you attach your file?
you mean the actual model?
akash.kamoolkar
@Anonymous Please attach the F3d file you programmed with the operations that dont work.
Akash Kamoolkar
Akash Kamoolkar
Software Development Manager
shane.waid
@Anonymous
Firstly, to save your file locally and attach it here:
  • Top left, click file, then export
  • Save file to known location
  • Insert file using the 'Drag and drop here or browse files to attach' dialog on forum web page.
When you create your second setup:
  • The WCS should follow over from the first setup, flip Z.
  • Under the second tab of the Setup page, 'Stock', Mode = From preceding setup
  • Check the box for 'Continue Rest Machining' if applicable.
I made the assumption that you are doing both setups on the same spindle, based on your wording and pic.
-Shane
