How To Sketch For Drill Then Boring Operation Help?
So I am having some difficulties trying to Sketch a drawing that utilizes a simple twist drill operation with a .25 drill then a boring operation to make the hole a final size of .29
Here is my question. OD of the part is .312 and is solid bar stock. I will face the stock, then Drill .25 and then would like to use a micro boring bar and make the final bore .29 the .25 operation is really only being used to open up the stock and give me room to get my micro boring bar inside (I need a minimum bore of .175)
So my question, when I sketch this part, I make my OD .156 then I create a revolve, which gives me a .312 diameter. Next I create a hole or sketch a circle. I make that .25 and the depth will be -.6 Next I want to come in with the boring bar and increase that .25 to .29 but this is where I am getting lost. If I draw a .29 Circle and choose a depth of -.6 then my .25 hole disappears. So should I just leave the hole .25 and when inside cam chose drill first and then choose Internal Profile and just work off the .25?
Does that make sense? I would like to see the part modeled complete, but don't know how to properly sketch that and apply a tool path.
@HughesTooling, has been a great help for me on this forum, I am looking at the file you sent me and it helped me define my tool, but the MM to Inches is killing me 🙂
If you read this, I would be more then welcome to have you take a look at my drawing and maybe save my day AGAIIN!!
