How to set the Traverse Height when leaving origin for start location?
Longbow907
Longbow907
I am working with a Laguna IQ router using the Laguna.cps Post from the fusion library.  When I click ok and initiate a project the Z axis lowers the tool to nearly zero regardless of the settings that I have set in the setup and traverses over to the starting point.  It is ok for now because i have been using flat stock, but what if there are features that I want to clear?  How do I set that initial movement height above the part?
Fabbunny69
Hi, if you export your file and attach here then sure somebody will help you:thumbs_up:
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Longbow907
Here is what I found.  While setting up the Post Process I noticed the lower portion (Properties) is minimized and I had not looked there to see the settings.  Under Properties there is an entry for Safe Retracts which is defaulted to G53 but allows you to select Clearance Height (set in tool path).  This raises the tool to the clearance height before it begins transiting to the entry point.
