Fusion Manufacture
How to Reverse Facing Toolpath Turning
13 REPLIES 13
Message 1 of 14
utekcnc
930 Views, 13 Replies
Attached is a screenshot.  I want to face from top to bottom, not from bottom to top.   How do I do that?  I'm using a profile toolpath.
13 REPLIES 13
Message 2 of 14
akash.kamoolkar
in reply to: utekcnc
@utekcnc
What kind of tool are you using? Could you attach your sample file here?
Akash Kamoolkar
Akash Kamoolkar
Software Development Manager
Message 3 of 14
Steinwerks
As @akash.kamoolkar stated it would help to have an example file, but this should be doable by changing the Direction to Back to Front on the Tool tab under the Mode & Direction section.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 4 of 14
utekcnc
in reply to: Steinwerks
Thank you.   Exactly what I was needing.
Message 5 of 14
stefanferencik
Hello Guys,
Can you explain please where/how to find "Back to Front on the Tool tab under the Mode & Direction section"?
I have issues with the tool direction during facing operation.
Thank you.
Message 6 of 14
seth.madore
"Back to Front" does not exist in the Facing toolpath, only in Profile Roughing and Finishing as well as Groove Finishing
Seth Madore
Message 7 of 14
Ok,
Then how should I solve this issue?
I believe that I did everything correct (videos/tutorials), but no way for me to change the tool direction. Can you advise please?
Message 8 of 14
seth.madore
I don't know what videos you're referring to, can you link them here?
And, to be clear; you want a "face" type path to go inside > out? You can get there with a Profile Finishing toolpath if you desire
Seth Madore
Message 9 of 14
Attached you can find my model. During simulation it is obvious that the tool should travel in -Z direction when is cutting.
Message 10 of 14
seth.madore
It is...
Are you saying that it's starting at the face of the part and working its way out? 
Seth Madore
Message 11 of 14
Yes, in my case the tool is starting the cut at the rotation axis and goes/cut in the radial direction.
In this video, time 4:30 looks different.
Fusion 360 CAM - Intro to Turning 03 - Face Turning - YouTube
Message 12 of 14
seth.madore
Where is your slider in the image below (this is in Simulation). It needs to be right-of-center. If it's left, Sim is running in reverse
Seth Madore
Message 13 of 14
Thank you. Solved.
When one pick with the mouse to this "button", it says speed, no direction.
BR,
Stefan
Message 14 of 14
akash.kamoolkar
@utekcnc This feature has been added to turning face operations in the latest update that recently went out.
Akash Kamoolkar
