Fusion Manufacture
How to reduce feed in sharp corners (lathe)?
1 REPLY 1
wengd
152 Views, 1 Reply
Hello
I'm cutting hardened tool steels with round ceramic inserts.  trying to avoid shock loads on the ceramic inserts to improve reliability.
Is there a way to adjust the parameters to create toolpaths with reduced feed in sharp corners? (adaptive roughing + profile finishing)
I am working with small batches, It would be nice not to have to adjust each program manually.
Thank you
Labels (3)
1 REPLY 1
seth.madore
in reply to: wengd
Unfortunately, no. I've also wanted to reduce feeds on small radii, but that's also not possible. This is certainly a place we could improve upon..
Seth Madore
