Fusion Manufacture
how to process a pocket of a turning part?
5 REPLIES 5
tmanger
251 Views, 5 Replies
Please help me!It is not possible to process the pocket to the full depth. the cutter only reaches the end of the part. The limitation of the processing depth is far behind the part. I have already tried all the settings, but the cutter does not go inside the pocket.
5 REPLIES 5
seth.madore
in reply to: tmanger
Hmm. I may be mistaken, but I think this is a current limitation of the Turning algorithm (the extended post is causing issue). To be sure, could you share your Fusion file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
tmanger
unfortunately, I no longer have access to the email. I can't open the mailbox and read the file
tmanger
uploaded the processing file
seth.madore
2 of those files don't have any toolpaths in it, and the third one I cannot open.
Please export your Fusion file and share it here again. If it's an assembly, you'll need to export it as a .f3z file
File > Export > Save to local folder, return to thread and attach the .f3d (or.f3z) file in your reply
Seth Madore
tmanger
in reply to: seth.madore
I did everything as you said.
