How to pick heights as "Selection"?
Rhino_3D
Rhino_3D
When I try to pick one of the heights as a "Selection", only the top
parts, directly on the surface of a body can be selected:
This does not work for any geometry below:
And when it's clicked, the "Selection" gets replaced with the file name:
In this example, it was possible to select the edge through the hole at the bottom, so I
assume that the overlayed height layers from Fusion are selected here.
So, how would I do this when I don't have a hole in the bottom?
Yes, one could create some additional points in a sketch or wherever,
but how can I pick any geometries through these overlays?
a.laasW8M6T
You have a sketch visible and are inadvertently selecting the sketch rather than the geometry you want,
Turn the sketch visibility off and you should be good to go.
I find this quite annoying but have gotten used to it.
seth.madore
Or you can "long press" with the left mouse button and select from the list that appears
Seth Madore
Rhino_3D
Thanks to both of you!
Turning off the sketch also has the advantage of less flickering, one of the
main reasons I avoid Fusion whenever I can :winking_face:
Thanks!
