& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
How do we cut tight inside corners with small bit after cutting with bigger bit? I tried running same tool path with smaller bit but then it tries to cut two tracks including outside one that I don't need. For example, cut contour with 1/4" bit. Then use 1/8" bit. Since 1/8 is half of 1/4, it follows contour on inside track, then follows separate track on outside. See attached pics.
Open up the operation for your 2nd tool. On the second tab, look at these settings:
Thanks. I will play with that and see how it work.
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
