how to make dados and rabbits
isa47
Message 1 of 25
isa47
Hello
I'm new to fusion and trying to figure out how to set up toolpaths for dados and rabbits in wood
parts. How can I make the tool go past the edge of the part to clear the radius of the bit.
and give me a clean straight dado with out the radius, or please let me know of the best
way you have found to make these types of cuts and any shortcuts to look into to make
that process faster when designing
Replies (24)
Message 2 of 25
seth.madore
If you are using 2D Contour or 2D Pocket (with open contours), you can adjust the Start/End extension, or turn on Stock Contours. Either method will scoot the tool out beyond the material.
Seth Madore
Message 3 of 25
Steven.ayars
Thank you Seth, yes most of my work will be done in 2d, to use with a CNC router
what if I'm putting parts on a full sheet of plywood? Will this still work? I will try to use it later today and see what happens.
Message 4 of 25
seth.madore
In the case of using full sheets of plywood, I would avoid using Stock Contours for anything other than those elements that are bordering the Stock, and even then it's going to be questionable. I would just you Start/End Extension, or Tangential Fragment Extension:
(view in My Videos)
Seth Madore
Message 5 of 25
Steven.ayars
Seth
thank you for the information. I'll have to play with this and see what works best. Do you have any ideas for best practices (pocket or contour) if I have multiple
dados and rabbits that run into each other, like the bottom of a cabinet for uprights? also, you don't happen to know how to set up a multi drill head (8 drills line bore) or would that be part of the post-processor
thank you again for the information
Message 6 of 25
seth.madore
Multi-drill heads are most certainly a post processor edit and nothing that can be handled on Fusion side of things. All you can do in Fusion is program a single drill and let the post take it from there. I'd suggest connecting with one of our resellers to help sort you out, you can find a list of them here: https://www.autodesk.com/support/partners?search=Post%20Processor&solutions=Fusion%20360
Regarding the overlapping contours:
Fusion works best with solid models, not DXF files. Looking at your shared DXF, it's not clear to me what's a dado/rabbet or uncut surface in some of the profiles.
In some cases, you can use Stock Contours to assist, but it's very situational.
Seth Madore
Message 7 of 25
Steven.ayars
Seth
thank you for all the information, I just sent the .dxf as a reference. I import the dxf from AutoCAD right now and then use it to turn it into bodies to program
But I am trying to use Fusion as a one-all program for CNC routers (primary) and then also for waterjet, but I am new to Fusion coming from Alphacam so i
am trying to get it to work the easiest, unfortunately, SCM group doesn't have a post processor for the Morbidelli 600k2 so Im trying to see if the one that is in fusion will work with this machine. But first, I have to learn to program in fusion.
again, thank you for all the help. I do appreciate it most of the information I am finding is more for milling metal and not so much for 2d routers
on another note, is there a way to tell the toolpath what order you want to cut
Message 8 of 25
seth.madore
@Steven.ayars wrote:
..on another note, is there a way to tell the toolpath what order you want to cut
On the Passes tab, select "Order by Selection"
Seth Madore
Message 9 of 25
Steven.ayars
I don't seem to have that unless I'm missing it. I do have a preserve order
Message 10 of 25
seth.madore
Eh, same thing. I was responding quickly without Fusion open to confirm the actual wording. My apologies 🙃
Seth Madore
Message 11 of 25
Steven.ayars
thank you sir
Message 12 of 25
Steven.ayars
ok another one for you. how to do 2 dados at the same depth but 2 different size widths, and they run across each other. using 2 different tools (1/4" cutter and a 1/2" cutter for the wider dado
if I design a part that has a dado that 1/4" wide that runs into another dado that's 3/4" and at the same depth once I extrude them down to 1/4" depth I cant pick
the face because then both areas are picked and the 1/2" cutter will want to follow the 1/4" area.
Message 13 of 25
seth.madore
Could you share a file that shows this sort of feature? 2D Pocket won't send a 1/2" tool into a 1/4" opening, so I wouldn't recommend using 2D Contour in this case. However, you COULD use 2D Contour if you are using the ALT key and selecting edges (not faces) of the model.
Seth Madore
Message 14 of 25
Steven.ayars
Good morning sir
ive attached a upper cabinet side and I think I figured it out. just a lot of steps, I used the ALT. key and that helped, I am using a 1/2" cutter for the main
dado and a 1/4" cutter for the backs. and you take a look and let me know if there is an easier way to get the dados that might be less time consuming.
again I'm new to the program and read about setting up tool styles to help with common tooling, so that is on my list to learn.
thank you again
Message 15 of 25
seth.madore
Because you're using a .250" tool and the opening is also .25", there's not a very good reason to select both sides of the slot. You can just select the one side and call it good if you prefer (considering you're working with wood)
Seth Madore
Message 16 of 25
Steven.ayars
my thinking for the 2 sides @ the 1/4" is so I can adjust the width for +/_ depending of the thickness of the material. that is why I wasn't sure if
pocketing a rectangle would work but haven't figured that out just yet. In alphacam you would make a rectangle for the dado area and then pocket
it out so you could adjust for material thickness. fusion is so powerful with parametric that once I can get it dialed in everything will hopefully adjust as
needed.
Message 17 of 25
seth.madore
Yeah, that sounds sensible. You can't use the Pocket toolpath when tool=pocket width, it will most often error out unless you have negative stock to leave.
Seth Madore
Message 18 of 25
Steven.ayars
you dont happen to know anything about post processors do you.  I got a name from scm group but the guy is in Eroupe and wants 1500 USD for the
one he wrote back in 1999. for a morbidelli 600k2 cnc work center
Message 19 of 25
seth.madore
I've got a basic understanding of post edits, what are you looking to do?
If you're US based, there are many resellers in the states who are quire proficient; DSI, NexGen and several others.
Basic edits; we should be able to help you here. Complex items (multi drill heads, head/head configuration etc) tend to be more "bespoke"
If you do seek assistance here, please start a new thread. This current thread is mainly for discussion of 2D Contour/Pocket along with rabbetts and dados
Seth Madore
Message 20 of 25
Steven.ayars
I will work on that tonight and start a new thread. thank you again
