Fusion Manufacture
How to keep 2D Contour from going past edge of stock
1 REPLY 1
arlinjv
92 Views, 1 Reply
I am using a Bantam PCB CNC mill to create some 'PCB art'. I am trying to cut a very shallow pocket to remove the copper cladding surrounding my design. The problem I have is that the PCB workpiece covers nearly my entire work area in the Y axis and so where the tool path leaves the stock it goes outside of the area that the tool can reach.
Is there a way to prevent the tool from passing the edge of the stock? If I can limit the amount it extends past the edge or only go off one edge that would work for me.
1 REPLY 1
seth.madore
in reply to: arlinjv
Would you be able to share your Fusion file, either here or privately?
Right click on the file in the Data Panel and select "Share Link". You can password protect it and DM me the link/pw or just share the file here
Seth Madore
