Fusion Manufacture
How to engrave flat areas?
4 REPLIES 4
herrpeterpaul
205 Views, 4 Replies
I combine 2D Adaptive Clearing with Engraving as described in this post . However, a small area remains, which cannot be reached by the endmill of the Adaptive Clearing operation. How can I clean out this small area?
Thank you for your help.
4 REPLIES 4
seth.madore
in reply to: herrpeterpaul
I'm thinking that a 3D toolpath might do what you're looking for, but it's hard to tell without a file. Could you share your Fusion file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
Hi, thank you. I attatched the file.
Take a look at the attached file.
First I changed the minimum cutting radius in the adaptive cut to 0.1mm to reduce the material in the corners.
Then I used a 2d pocket with rest machining enabled. Note you can't use a spot drill so I used the chamfer mill you'd set up. Also I edited both tool and set the tip[ to 0.1mm as I doubt the tool has an exact point.
For rest machining tool diameter you need to add the stock to leave from the first pocket plus minimum cutting radius x 2 + cutter diameter. So I just used 3.5 + 4 = 7.5. Then set the max stepover to 0.2 and radial stock to leave to 2mm give this toolpath.
Mark Hughes
Owner, Hughes Tooling
Thank you! That was really helpful.
The important points for me were to use an additional 2D Pocket with Rest Machining enabled and a Maximum Stepover to clear out the area.
I tested engraving with the chamfer mill as well. This works, however, I had to add a bit of extra to the formula. So something like (stock to leave of first pocket + minimum cutting radius) x 2 + cutter diameter + .5
And just for completeness the formula to compute the stock to leave is: tan(angle of chamfer mill) * pocket depth.
Thanks again
