Fusion Manufacture
How to duplicate element with defined CAM work?
3 REPLIES 3
848 Views, 3 Replies
Hi
I have element with defined CAM parameters.
After cutting first prototype I want to cut a few (ten for example) pcs of this element
from one sheet of material at once. Not ten pcs one by one...
How to duplicate / copy parts with defined CAM parameters?
Jakub
3 REPLIES 3
curtis.chan
Hi there,
Would love to see what you're cutting. I put a video together on using patterns, which should help you out. https://youtu.be/DezTxhHQua8
in reply to: curtis.chan
Hi
Check this video: http://youtu.be/fuSWPw-oI7Y please.
It's relative easy element, I have complicated products to cut 😉
Now it's only test batch - two elements - fife copy of each, so I can prepare CAM one by one,
finally I'll cut probably 40-50pcs from one sheet of aluminium.
I want to prepare CAM for one element then copy it 50x...
Is't possible?
Jakub
It's working 🙂 Pattern is a solution, thank you 🙂
Jakub
