Fusion Manufacture
How to create a chamfer on x and Z
9 REPLIES 9
Message 1 of 10
jdkendall97
250 Views, 9 Replies
I have a nasty burr on the blue edge shown on the picture and I want to take a 45deg chamfer mill and cut a small chamfer.
So the cutter would only move in Z and X. I have tried a regular 2D chamfer but it doesn't work. What can I do to do this?
9 REPLIES 9
Message 2 of 10
engineguy
in reply to: jdkendall97
@jdkendall97
It would of course be best if you can angle the part in either a fixture or using a 4th axis but as it doesn`t look to be a very big angle possibly the "Trace" toolpath will do a good enough job for you.
Or you can maybe try a 3D toolpath like the 3D Contour, just ideas 🙂
Message 3 of 10
jdkendall97
in reply to: engineguy
3D contour says I cant use that tool. I tried the trace toolpath but it doesn't want to move the tool over. see picture. I tried the stock to leave and chamfer options but both of them had the center of the tool directly on the part. But trace is giving me an angled tool path. What do you suggest?
Message 4 of 10
seth.madore
Can you share the Fusion file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
Message 5 of 10
jdkendall97
in reply to: seth.madore
here it is
Message 6 of 10
seth.madore
Are you trying to put the chamfer on in OP1 Undercut or OP2 Angle?
Seth Madore
Message 7 of 10
seth.madore
If you want it in OP1, set your Trace to this:
Seth Madore
Message 8 of 10
jdkendall97
I was trying for OP1, because it might be rotated it OP2 and not look even.
Message 9 of 10
jdkendall97
Oh the sideways composition was set to center. I think that is it.
Message 10 of 10
seth.madore
Alright, the image above should get you what you're looking for. That said, I'd encourage you to use a bull or ball nose endmill and use a 3d toolpath such as Adaptive or Parallel to rough off excess material, you're taking quite the cut with that chamfer mill (unless of course, it's a soft material or you know the tool is good for it)
Seth Madore
