How to compensate the Pendulum Length of a 4 axis milling cnc
12:34 AM
i'm having some trouble to use this new 4 axis machine with fusion360, i can't find out where i should input offset/compensation for a correct gcode, i'm using a "generic 4 axis model" with a head with Z and A and a table with X and Y (wich is 100% correct) i'm using fanuc.cps the machine like it except for commad G43.3 changed then in G43.
The program in simulation is correct (in fusion360 and also on the machine) but when i run the program the A axis is moving more fast than the X axys (for the pendulum compensation) and i don't know what i can do, hope for some help 🙂 Thank you
