How to CNC multiple stock from single design
Hey folks,
My project is a campervan floor. I have a single design that breaks the floor down into four different sections since the campervan is much larger than a single sheet of plywood. I am struggling on how to move from design to manufacturing given that there will be 4 different stocks and 4 different CNC programs as a result. Each piece is a component in my design file. For simplicity, assume that I will use 4 full sheets of plywood with a single component on each. I was thinking I would just have 4 different setups in the same file. I am struggling a little bit with how to select only one component for each setup. How should I be thinking about this? Can I do this in a single file or do I need to create individual files for each job and import the floor design into each, then delete the components I don't need in that one specific file? Ideally I would like 4 different setups with a board layout for each in a single file, then output 4 different programs, of which I just take to the CNC and cut 4 different sheets.
