Fusion Manufacture
How to change cut pattern of 2D Pocket
2 REPLIES 2
Yaroslav.MudritskyC75UA
98 Views, 2 Replies
Actually I'm using 2D Pocket as standard. For a particular manufacturing process I'd like to apply forward-back pattern instead of spiral one.
Here's what I mean:
Actually is generated like this
I need something like this:
I've tried to use Face, but I can't use it on an inside cut because it will ignore borders.
Any suggestions?
2 REPLIES 2
One could use 2D Contour and Roughing Passes, but then you're lest messing around with Lead-in/out moves.
Another option is to use Parallel:
Seth Madore
Yet another option is to use the Flat strategy:
Seth Madore
