Fusion Manufacture
How to attack a pocket in material
5 REPLIES 5
bradheller
194 Views, 5 Replies
Hey Fellas,
I'd like to ask advice on how someone would attack the following shelf cut in the side of material. I'm using a CNC Router cutting MDF and I'd like to achieve it all by using a 6mm 2F Straight Cut bit. I've cutout the silouhete of the part but I need to cut out the slot in the side of it. Because it slopes down and away, the pocket tool doesn't work like the rest of my pockets. The rest of my pockets are nice and flat.
I've tried all different types of cut but I have no idea what I'm doing. Hope someone can help.
5 REPLIES 5
It might help if you can post the fusion file. Easier to see what you are trying to do and comment/help....
Cheers!
seth.madore
in reply to: bradheller
I think this is Part 568 from your nesting file that you were struggling with earlier. What sort of finish are you looking for? Square internal edges, or is a fillet acceptable?
Likely the easiest to do would be just a Trace or Scallop toolpath. Examples attached
Seth Madore
bradheller
in reply to: seth.madore
Thanks for the help again Seth. The Trace function is the only one I managed to get to work but it only follows a single line and doesn't cut out the entire pocket.
seth.madore
What sort of finish are you looking for in the pocket, and what do you have for tooling at your disposal?
Seth Madore
bradheller
I want to stick with the 6mm straight cut bit. I think I'll stick with the trace and finish off with a chisel. Its only a one off job for myself.
