How to 5AX simultaneous Impeller Machining
cadcamd4
cadcamd4
I'm confusing about how to start to do 5ax simultaneous machining of impeller.  I'm trying to find but no information about this.
How to do rough cut?
How to do semi-finish?
How to do finish?
Could you pleased guide me how to start?
Drew
arie.fournier
I had to do a swirler turbine a couple weeks ago. Luckily the height aspect ratio was within 2/1 so making tool paths was more forgiving. I ended up using a "wrapped" 2d Adaptive (you can find the option under geometry) for the roughing and swarf with a spiral step down. to finish the fins.
