Fusion Manufacture
How should I use "Sketch Profiles" for the geometry of a 2D Pocket strategy?
2 REPLIES 2
Sadovshikov_Vitalii
128 Views, 2 Replies
When the "Sketch Profile" option is selected I get the wrong path meaning the path goes all around the pocket (selected sketch) instead of inside. If I apply the "Chain" selection, everything works as expected, with the path inside the pockets. How can I achieve the same result as utilising "Chain" but using the "Sketch Profile" option?
2 REPLIES 2
Okay, I've find out, I should have enabled start inside option
Set it to "Start Inside"
Result:
Seth Madore
