How do you program from multiple models in the same setup
Hi Everyone,
Can someone explain how I can program from a manufacturing model (which I created to help with some tool paths) and the master (customer) model in the same setup.
Steinwerks
In most toolpaths there is a Model override button on the Geometry tab. You can use this to add additional geometry or override the Setup model completely.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
MattWynn
You must use different setups for the design model and the manufacturing model. Pick the default model or manufacturing model at the bottom of the setup dialog.
The manufacturing model is a derive of the design model and they are completely different models.  Changes to design model will propagate to the manufacturing model, and in the manufacturing model you can make modifications (that have a history and can be replayed when the design changes).
Matt Wynn
Senior Manager, Software Development, Fusion Fabrication
Steinwerks
I should note that I avoid using Manufacturing Model entirely so I'd listen to @MattWynn 😛
Neal Stein
Find me on:
Excellent. Thanks!
So how do I make the timeline for the manufacturing model visible?
MattWynn
@Anonymous I see it appear when I make an edit, like add a hole.
Matt Wynn
