How do I refresh my Post Library
sam.byrnesKB9TR
sam.byrnesKB9TR
The cloud post library in Fusion 360 doesn't match the Assets/Cam Posts folder on A360.
When I look at my post library on fusion there are multiple posts which I have moved to a separate folder on my A360 drive, and there are also post in my A360 drive which aren't showing up in fusion.
Attached photos:
You can see on my A360 Drive I have a post called "Setup-Sheet.cps", I was using this post this morning from Fusion, then I uploaded a new version of that post and it has disappeared from within fusion.
I have tried clearing my local cache using the drop down menu under 'Support and Diagnostics'
I have also deleted the "M" Folder from within: Appdata/Local/Autodesk/AutodeskFusion360/(Random Folder Name)/W.login
seth.madore
Have you signed out of Fusion and then signed back in? Sometimes the sync gets "hung up" and usually this is the first step to try
Seth Madore
sam.byrnesKB9TR
Yeah I have tried that, also tried signing into a different fusion account that is on the same Team and the posts still wont refresh. The issue seems to persist across all the users in our TEAM, we can see the post on the A360 drive but when you look at your post library in Fusion sometimes the library will update other times it wont.
Any chance my antivirus software could be blocking or slowing down fusion from refreshing the library?
seth.madore
Okay. I've pinged one of the architects, hopefully he has some advice...
Seth Madore
jeff.pek
The first thing I would have suggested would be to shut down Fusion and rename that M directory. Could there be more than one -- associated with different logins? Can you show a snapshot of what's in that M directory, under another "secret" subdirectory there.
Jeff
sam.byrnesKB9TR
I got to the bottom of it. I had made an edit to Ln 79 and that was causing it to not show up in my Fusion post library, I changed Ln 79 back to what it originally was and it appeared.
Thank you both for you help, it is greatly appreciated.
jeff.pek
Glad you got it sorted!
  Jeff
