how do I make a cutout template
brand new to 3d modelling and autodesk fusion - so this is probably the first of a succession of dumb questions however...
My problem:
* I have a small bed 3d printer - I want to break lots of things up in a way that they just snap together
My idea:
* to make tabs - so - suppose I have a flat 3mm thick surface A I want to connect to another flat 3mm surface - then I have 3-5 1mm thick 3mm wide tabs sticking out of each one - some on the top pointing down, some on the bottom facing up ... and on the _other_ side of the surface I have a corresponding hole - so hopefully I align them, push them together and they click in place never to come apart again, and look fairly seamless...
So here is my design for the tab and the hole it will slide into - assuming there's a certain amount of flexibility in the tab:
Now - I get that I can just copy and paste the tab a lot and connect it to the edge of my half object... but what I don't understand is how do I sort of copy and paste the corresponding "cut out" - that i need to remove from the other half object? I sort of want to capture the stuff that's not there, and cut that shape into a big solid at various places.
(and generally - is there a better way of doing this, or achieving my aim?)
