Fusion Manufacture
How do I install the postprocessor for a Tormach 440 Mill?
2 REPLIES 2
734 Views, 2 Replies
I'm very slow.
Is there a video I can watch to learn how to install it?  Or a link?
thanks
2 REPLIES 2
HughesTooling
Are you using a PC or mac. If you're using a PC click the post button from the CAM workspace, on the post dialog click setup and select personal posts, you will then see the path where you should store your post.
Mark
Mark Hughes
Owner, Hughes Tooling
jeff.walters
If you’re not using the sample posts you can go to your A360 Drive and put it in the CAMPosts folder. Then go to you Fusion preferences, under General/CAM check the Enable Cloud libraries. This will work for PC and MAC.
https://myhub.autodesk360.com/ue29c4870/g/projects/drive/data/root
Jeff Walters
Senior Support Engineer, CAM
