Fusion Manufacture
How do I drill multiple Radial holes in one operation
5 REPLIES 5
tgford58
239 Views, 5 Replies
I apologize for the basic nature of the question.  It's my fault for not spending enough time programming Y axis jobs.  But... How do I drill more than one radial hole around the OD of my part.  I'm sure I am missing a simple step but it is eluding me.
Thank you for any help.
5 REPLIES 5
seth.madore
in reply to: tgford58
Assuming all holes are identical in size and depth (and all on Y zero), I prefer to program one of them and then put it into a Pattern > Rotation.
Seth Madore
tgford58
in reply to: seth.madore
@seth.madore   I don't see a pattern function in CAM.  How do I locate that?
My work around is to have a separate Drill function for each hole and change Tool Orientation for each.  Sort of messy.
Thank you for your help.
weber_dominic
Right click on your Toolpath/Operation and and add a new Pattern. Not sure how it's called exactly because i run it in German. It's like a Folder Icon...
seth.madore
Right click on the toolpath and select "Add to New Pattern".
Seth Madore
tgford58
@seth.madore @weber_dominic .  That is slick.   I have never had the occasion to use that function before.
Thank you both for helping me.
