Announcements
How do I change the file extension from .nc to .txt
I need to change the file exyension from .nc to .txt, I think....I have a HAAS TM1 that was new in 2000. All the files that I normally import from floppy are in .txt. After finalizing a cam file I want to try to get it to the machine but i cannot change the file extension from .nc to .txt in the post process window...This is the trial version of  fusion 360 for students and start ups.
Replies (9)
LibertyMachine
Assuming you are on a PC....
Open up your Post Procecesor.
This can be done by going to the Post process dialog box, making sure your post processor is selected and clicking on "Open Config".
This will give you an almost literal wall of text. Don't be alarmed and overwhelmed. You are looking for a line of text that's going to be within 25 lines of the top.
Search for this line:
extension = "nc";
and change it to this:
extension = "txt";
Now, you need to save the Post Processor. DO NOT save it in the generic folder. It will get wiped out next update. Save it to a folder you create in the C:/ drive or a folder of your choice. Alternatively, you could store it in the cloud once you have it how you want.
Next time you go to post out a job, you will want to direct the dialog to utilize Personal Posts and search for the location.
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Thank you very much, ill will try it.
Okay, I can change the extension but it did not fix my problem. When I try to import to the control from floppy, yes floppy.....the control says disk read error. I can write and read a program already on the control. Maybe the file is too big...
HAAS TM1
Ver M12.08N
MOCON 12.05
Im using the generic Haas Milling post
Steinwerks
Can you attach the code file? It shouldn't care about the extension. It'll try to load Excel files if you hit the button 😂
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
I can, and will tomorrow. I didn't think that it mattered which extension I was using. Im trying to eliminate as many possible causes. The file looks good in notepad and matches other programs as far as I can tell. The file is 130kb. Most of my other programs are 3-5kb. The control shows over 750kb free memory. Maybe the floppy drive is too slow?
kshea9RNL8
Floppies are now old and are subject to deterioration, have you tried a new floppy?.
I was always getting disk read errors and went to a floppy/usb converter and never looked back.
Here it is. So I split the code into 3 sections. The first two sections loaded without a problem. The third gave the disk read error again. Also I cannot edit the code on the machine because it is guarded, that may be something in the post editor I can change?
JKChesher
I have recently made the switch to a usb/floppy converter as well.
Is there anything special to do with the programs to get the haas to read it off the converter? I could have sworn you have to do something with the file before loading it onto usb?
kshea9RNL8
Nothing to be done to the program, just load it onto the flash drive in it's required format , the flash drive however does need to be converted and named  to be compatible with the floppy converter. You should have gotten software to do that with the converter. There is also a little button on the converter that changes the floppy number (0to99 I believe) that it is reading and your program is on.
The converted flash drive size is recommended to be no larger the 4gb, if your converted  flash drive is larger that may be causing issues though I've not tried any larger flash drives to see if they cause problems.
Ken
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
