Fusion Manufacture
How do I change entry point when using 4th axis rotary parallel strategy?
4 REPLIES 4
kksAZZV7
68 Views, 4 Replies
Hello
Is there a way to change the entry point for when using 4th axis rotary parallel strategy? 🤔
I would like to switch between entry point and where the tool goes out.
I look forward to hear from you.
4 REPLIES 4
seth.madore
in reply to: kksAZZV7
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
kksAZZV7
Here you go. 😊
seth.madore
Flip these around:
Result:
Seth Madore
kksAZZV7
Great! Thanks!
