Fusion Manufacture
How do I avoid Parallel to rapid into stock.
4 REPLIES 4
ian1196
159 Views, 4 Replies
In general if I have a subsection on a part and I cut a 2DContour around the section. I then use Parallel over the subsection. Parallel will rapid through any remaining stock to get down to the subsection. Can I avoid this rapid lead in?
4 REPLIES 4
seth.madore
in reply to: ian1196
Parallel is not "excess stock" aware, only Model aware. I would likely chuck on there a 3D Adaptive that's been constrained by some sketch and heights.
Seth Madore
ian1196
in reply to: seth.madore
Thank you, I thought it was something like that. I never had much success with Adaptive Clearing. It takes too long to process and mill. Pocket seems much better. Flat is also slow to process but it is better than Horizontal.
jscott6SWZG
Yup i have been struggling with this.   Thanks for the hint
HughesTooling
Can you share a design where you have an adaptive toolpath set up? If you've set it up as a pocketing toolpath it will take a lot longer than an open pocket (clearing the top of a boss).
Mark
Mark Hughes
Owner, Hughes Tooling
