Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
How do I alter my cut path for plasma cutting?
2 REPLIES 2
1180 Views, 2 Replies
I'm using fusion to model parts to transfer to my go torch plasma CNC which uses design edge software. I use the torch mate post processor to transfer everything to g code, which seems to work a lot better than using .dxf format like the plasmacam instructions say. Everything cuts great except for that I can't figure out how to designate which side of the line to pierce on. It seems to want to lead in from the inside on every cut, and that ruins the outside edge of my parts. I would like to be able to designate the order of the cuts and also where to lead in. Any info would be appreciated
2 REPLIES 2
HughesTooling
When you pick a profile these a red arrow showing the direction of cut, just click it to change the direction\side.
Mark
Mark Hughes
Owner, Hughes Tooling
in reply to: HughesTooling
Thanks for the reply. That worked!
