Fusion Manufacture
Horizontal Ignores Heights
5 REPLIES 5
ian1196
113 Views, 5 Replies
My Horizontal Mode tool motion runs tooling higher that the bar levels. Why? How to remedy
5 REPLIES 5
seth.madore
in reply to: ian1196
I'm not sure exactly what you mean, do you have a file or an image you can share?
Seth Madore
ian1196
I just learned that it adds the depth on top. Here is an examples that follows the levels. However, it plunges into the part.
I thought helix would prevent this.
seth.madore
As a Finishing toolpath, the Horizontal toolpath is not aware of the stock, and the same goes for pretty much all of the other Finishing toolpaths (Contour, Scallop, Flat etc etc). The Horizontal or Flat toolpath should primarily be used for finishing, keeping in mind it's not designed for stock awareness. I'd recommend using a 3D Pocket (or Adaptive) toolpath to rough this part out.
Seth Madore
ian1196
I always give Adaptive a chance and it is mostly junk.
seth.madore
How so, do you have an example you can share (where the toolpath is less than desired)?
Seth Madore
