Fusion Manufacture
Higbee / blunt start broken since latest update?
7 REPLIES 7
Message 1 of 8
ggtechV76F3
193 Views, 7 Replies
Has anyone else noticed Higbee is broken since latest updates?
I was trying to make a new Higbee but would not seem to show any tool or tool path. It did generate with no errors.
To test I was not doing something silly I went to another model with known working Higbee and regenerated, which instantly broke it. no changes to the setup or options. I attached the screen shots.
What I notices is that the time estimate went to some huge number. In any case I cant seem to make any new Higbee's or change any of the existing ones I have.
Is this a known issue?
7 REPLIES 7
Message 2 of 8
@ggtechV76F3 can you attach your file here so i can take a look?
Akash Kamoolkar
Software Development Manager
Message 3 of 8
ggtechV76F3
in reply to: ggtechV76F3
@akash.kamoolkar here is a working blunt start/higbee. If you make a change, or even just regenerate with no change it breaks somehow.
Thanks for having a look.
Message 4 of 8
TrollTuner2
I had a stock error when trying to simulate it and then a hard crash.  748899958
Message 5 of 8
ggtechV76F3
Interesting - I am able to simulate. Here is vid of before and after re-generation.
Message 6 of 8
@ggtechV76F3 i have managed to replicate the issue. we have a fix already that should go out in an update soon. for now a temporary workaround would be to set number of stepdowns to greater than 1 and it should work.
Akash Kamoolkar
Message 7 of 8
ggtechV76F3
Yes, I did also discover multiple step downs is a work around. Thanks for the help, and look forward to the fix.
Message 8 of 8
@ggtechV76F3 This issue was fixed in the update that went out yesterday.
Akash Kamoolkar
