Fusion Manufacture
Help with tool path
3 REPLIES 3
endicott.12
110 Views, 3 Replies
Help with tool path
Could anyone help me extend this tool path on down the part?
The green stock doesnt seem to be coming to a sharp corner.
3 REPLIES 3
a.laasW8M6T
in reply to: endicott.12
It looks like  the bottom height setting is "Model bottom" which means the tool tip cannot go below that level.
If you give an additional negative offset of the tool radius then you should be able to machine all the way to a sharp edge
endicott.12
in reply to: a.laasW8M6T
Thank you so much,
what you said as well as tool outside of boundary.
a.laasW8M6T
Hi, a better option than tool outside boundary IMO is to use tool center on boundary with "contact point boundary" checked
