Fusion Manufacture
Help with strange plunge outside of selection?
3 REPLIES 3
jscott6SWZG
134 Views, 3 Replies
I have a 2d contour that works properly....(it is the original sketch for a mirror for the next 2 d contour).
I duplicated this contour, then selected the new contour (reversed of course).
but this contour has a plunge at the end of the tool path that i cant get rid of and have no idea where it is coming from.
Set up is spring slot lever drill; operation is 2d contour34(3)
3 REPLIES 3
yd_kwon
in reply to: jscott6SWZG
Hello.
It's the chain of 2D toolpass that's the problem.
Inside the chain, which was created by combining the sketch and the edges of the geometry, there is a warped section.
If you generate a toolpath that excludes those warped sections, you can see that it comes out fine.
I've attached a short video to demonstrate this.
Good luck.
iCetnric - MFG
CAM-Fusion 360/Inventor
CAD-Fusion 360/Inventor
Before PowerMILL
Tags (2)
jscott6SWZG
in reply to: yd_kwon
Wow great find thanks a lot YD.
I have never used wireframe view...looks really nice.
Think I need to reboot fusion, and review my timeline start to finish...figure out where the warpage is coming from.
yd_kwon
I usually use it as a hotkey.
ctrl+6/ctrl +7
iCetnric - MFG
Before PowerMILL
