Help with retract ID turning
nordlund4V6AKB
nordlund4V6AKB
Hi!
I'm boring this ID and i want the boring bar to retract  15mm from model front in cycle. It seems it retracts fine the first cuts, but when its roughing out the grooving it stops to retract. I want it to retract all the time and i can't seem to find a way around it other than to program it by hand.
akash.kamoolkar
@nordlund4V6AKB is this for chip evacuation? If so the recommended way to do it is by overriding your safe z parameter in the links tab to wherever you want to retract in Z and then set the "retraction policy" in the links tab to "full retraction".
Akash Kamoolkar
Software Development Manager
nordlund4V6AKB
Thanks alot! That was exactly what I was looking for!
