Fusion Manufacture
Help with angles
1 REPLY 1
brianw6ZAM
76 Views, 1 Reply
Help with angles
I have attached the file for the part I'm struggling with. I can get all the 2D portions programmed just fine. I can't seem to get a decent tool path for the angles on the right hand side of the part that go down and out. We have not purchased any extensions either but I would think this could be done in Fusion no problem. Thanks in advance.
1 REPLY 1
seth.madore
in reply to: brianw6ZAM
Go into your Preferences and turn on the Blend toolpath in your "Preview Features". You can get this for a toolpath:
That said; you're still going to run into issues with the result, since you're going to end up with whatever corner radius of the tool you end up using (I'd suggest using a ball endmill)
Seth Madore
