- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm having a heck of a time getting a .25" tool to machine a .351 wide cavity. The attached images explain it better than I can. I believe it as something to do with the tool not being able to adaptive around the corner. If you look at the sim and the tool path, you can see it has no issues until it reaches the corners where it has to raise the toolpath in order to machine the cavity on the end. Its necessary for me to leave .024 stock in both axial and radial, so changing those values cant be part of the solution. Any advice on how to fix this is appreciated. The attached model is only a section of the model I'm working on.
Fusion
