Fusion Manufacture
Help! with 2D cutting profile Contours...
4 REPLIES 4
andyWEWEL
205 Views, 4 Replies
I'm hopelessly stuck on this, and have sunk way too much time trying to figure it out.  In my welding class we were taught how to make family name signs with TorchMate.  At home however I have a CNC plasma cutter that I've built.  I've successfully cut things I've designed in Fusion 360, but the name sign thing is just not working...
When I try to select the Contours in the 2d cutting setup, all I can get it to select are line segments on the profile.  I've checked a dozen times looking for a loop that isn't closed and I can't see anything.  In the design I have no white point markers.  I can't spend hours trying to select every line segment in the contour selection - I'd surely miss one, and Fusion 360 starts to freak out and stop working right when the number gets too high.
My sign looks like this:
When I try to select the contours on the outside, I can only get the segments:
I can get some of the closed sections to work right, like this, but not the profile:
Any help will be appreciated.  What did I do wrong?  FWIW, if I save this as a .STL file, I could 3d print it (shrunk down) with no problems.  It just can't get Fusion 360 to generate g-code for plasma cutting, because of this issue with the contour selection.
Labels (2)
4 REPLIES 4
seth.madore
in reply to: andyWEWEL
The issue is in your Setup WCS setting:
Seth Madore
engineguy
@andyWEWEL
Ah, I see that Seth has posted just before me, faster than me 🙂 I will post my version anyway just for your interest 🙂
andyWEWEL
Thank you so much!  I don't know how I didn't notice that I had the axis wrong, but thank you for the kind and thorough explanation of how to fix it!
andyWEWEL
in reply to: seth.madore
Thank you!  This is very helpful!
