Help understanding Tool Orientation in Parallel toolpath
tgford58
Message 1 of 8
tgford58
I need some help from users more experienced that me.   I am programming a BNEM as a finishing operation using the Parallel 3d function.  My goal using the WCS is to have the tooling move in the Y axis following the Z plane and stepping along the X axis.  To achieve this I used Tool orientation to spin the toolpath 90 degrees.
I'm probably overthinking the issue but does Tool orientation look to command a C axis rotation or is this simply a software calculation that still utilizes the WCS?  I've attached the file and my work can be seen at Op 5.
Thank you for your patience.
Replies (7)
Message 2 of 8
seth.madore
I'm assuming that your machine does indeed have a trunnion on it?
There are two ways to get the Parallel going the way you want:
Tool Orientation (as you've discovered)
Pass Direction, which is found on the Passes Tab. Select a line segment that would represent your directional preference. You can also apply a degree value instead if you prefer
As to whether or not it commands a C axis move;
Do to this being on a trunnion and a different orientation from your Setup WCS, I would expect to see a C axis command (assuming your trunnion has an A/C designation)
Seth Madore
Message 3 of 8
tgford58
@seth.madore  No,  I do not have a trunnion.  Strictly a 3 axis machine.
I've never used Tool Orientation before, I've always utilized the pass direction you mentioned.
Tool orientation seemed like another method of adjusting my tool path.  Until I better understand its use I'll stick with pass direction.
Thank you for your time.
Message 4 of 8
DarthBane55
tool orientation defines the axis, the Z being the spindle tilt.  If your machine is 3-axis only, you cannot use tool orientation, because your tool cannot tilt in any way.
Message 5 of 8
tgford58
Thank you. I did post the code and the moves were along the X and the profile was created in the Y-Z plane. Odd but I switched back anyway.
Message 6 of 8
tgford58
To add, I switched back to defining the tool direction and posted that code too.  In a cursory look the code generated using Tool Orientation vs Tool direction look fairly identical.  @DarthBane55 @seth.madore  Is that possible?
Message 7 of 8
DarthBane55
If your Z was tilted and the code is identical, it's most likely because your post knows you don't have A-B-C axis, so it keeps it straight anyways.  I can't really see another explanation.  So it might work, but you may one day rotate the X-Y and then your code will be screwed up big time (rotated 90deg or something).  You don't have A-B-C, leave the tool orientation unchecked.
I'll let @seth.madore  explain exactly why your code is identical because I am not 100% if my explanation is correct.
Message 8 of 8
tgford58
Thank you for all of your help.   I thought I was sort of pulling the tigers tail so, for now, I'll leave that one alone.
