Fusion Manufacture
Help! Siemens 808d (Mill) PostProcesor ERROR
3 REPLIES 3
jofra98
139 Views, 3 Replies
hello!
I am using Google Translate for this post.
I started machining with a Siemens 808D (3 axes) and initially I use AlphaCAM. When trying to use Fusion 360 with the library's PostProcessor I get an error, the code is not correct.
I attach the alphaCAM configuration and the one returned by Fusion360. I hope you can help!
3 REPLIES 3
serge.quiblier
in reply to: jofra98
Hi @jofra98
can you share the error message, or a picture of the controller screen showing the error state?
Without knowing on which line, and what the error message is, it's like looking for a needle in a haystack.
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
jofra98
in reply to: serge.quiblier
Hi!
the error is this:
010720: Sequence 31 x-axis software limit switch -
010720: Sequence 31 Y axis software limit switch +
The spindle moves in Z upwards
serge.quiblier
Apparently the gcode is generated with helix, but without circles?!
But in our library version, both moves are activated.
Do you had issues with arcs previously?
To remove the helix support, you can change the line:
allowHelicalMoves = false;
But the error message on the controller is just saying that some coordinates seems to be outside of the machine limits.
Serge.Q
cam.autodesk.com
