Help, postprocessor for DMU 100 T since 2002 , 3 axes
arna_mould
arna_mould
Hello, I recently started using fusion 360 and I'm facing a processing problem
I installed the millplus postprocessor that I found in the library, but unfortunately it doesn't work, there are g codes that the machine doesn't recognize.
The software of the machine is Millplus and when it loads it says something like tnc 246268 01.
Thank you very much
seth.madore
Do you have any g-code produced by another CAM package that you can share with us?
What sorts of G and M codes are giving you issues?
Seth Madore
