HELP!!! on cutting a skateboard.
I made a wood mold and compressed with the layers of sheets and trying to cut it to size.  Only I can think of is using 2d- trace but the problem is the edges that have 45 degrees(red arrow) to be cut.
What's the best option to use in Fusion 360?
Thanks !
LibertyMachine
Scallop would be my first try
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Seth,
Thank you for the prompt response.
I did a quick try on Scallop feature but this is what I am getting.  what setting should I change to make this work?
LibertyMachine
It's set to Silhouette for your Machining Boundary. Set it to "Selection" and select the areas you want to cut. If you share your file, I can knock out a quick demo video for you
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Seth Madore
That'll be awesome.
Please see the attachment.
Thanks a lot!
LibertyMachine
Seth Madore
Seth,
I really appreciated the video,  There are other areas that I need to practice on.
Thank you again.
