Fusion Manufacture
HELP! 3D toolpath on negative angle using T Slot bull nose.
6 REPLIES 6
MetalRipper_
200 Views, 6 Replies
Hi folks
I need your help in making a finishing toolpath. The selected blue area has a negative angle, so i want to finish it with a T shaped bull-nose but I'm not able to generate any toolpath with it. Kindly help.
Thanks.
Gokul Kannan
Making Parts at MetalRipper using Fusion 360
Youtube.com/@metalripper-
CNCexpert.com/gokul-kannan
6 REPLIES 6
Marco.Takx
in reply to: MetalRipper_
Hi @MetalRipper_,
Do you have the extensions?
From viewing the picture the Steep & Shallow strategy will do the job for you.
But it's one of the machining extension toolpaths.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Consultant
MetalRipper_
Hi @seth.madore  @programming2C78B  @a.laasW8M6T  @HughesTooling ,
Can you help with this?
Please suggest if there is any alternate way in getting it done.
Thanks.
Gokul Kannan
seth.madore
3D Contour will do the job, it also detects undercuts:
The above is just a rough toolpath, little time was spent on dialing it in.
Seth Madore
MetalRipper_
in reply to: seth.madore
Hi @seth.madore
I'm stuck with the following error, using 3D contour path. Can you please share your file to find out what I'm doing wrong?
Thanks.
Gokul Kannan
Hi @MetalRipper_
The error is related to failure in linking (can't link some cutting paths). I can check it if you attach an example where it happens.
I've created derived Contour operation (as @seth.madore has suggested) using your Flow operation and specified the following machining boundaries and touch surfaces and it works for me. Please try it.
Oleg Tikhomirov
Software Engineer
MetalRipper_
Hi @oleg.tikhomirov
Problem solved. I looked around the forum and found a file Seth shared previously and copied the toolpath to generate mine. Yet to investigate the issue. Attached the link to my for reference
https://a360.co/46SrRI7
Thank you.
Gokul Kannan
